Standmounts that rock?
SonofSun
I am really happy with my system, however ,I have never tried a decent pair of standmount speakers in my room (4m by 4.5m). What I intend to do is buy a pair and see how they compare against my GB1i's.
I will probably go the ebay route, so if I don't like them I can them sell them on without losing too much.
My budget will be up to £1k. I play mainly guitar based music indie/rock etc.
Any suggestions?
shooter
210
If you sold the PMC and put a grand towards some Totem Mani II signatures you wouldn't want the PMC back.
From one very content Totem enthusiast!
What are you aiming for? What don't you like about the GB1i? The obvious choice would be the DB1i (which can be had for a steal at Lintone Audio on ebay) but I'm not sure whether they'll do anything for you.
If you go PMC route I would say (given I've heard the DBs) TB2 would be better suited for rocky-type music. Otherwise I'd look at Dynaudios - all Dyns really are party animals.
SonofSun
igglebert:What are you aiming for? What don't you like about the GB1i? The obvious choice would be the DB1i (which can be had for a steal at Lintone Audio on ebay) but I'm not sure whether they'll do anything for you.
I just want to see whether a decent pair of standmounts sound better in my room. The PMC TB2+'s have interested me (bigger drivers) but I was outbid.
I am curious to see whether good standmounts might be preferable to equivalent priced floorstanders.
shooter
210
plastic penguin:all Dyns really are party animals.
Yep and the Mani's are isobaric dyn drivers topped with a SEAS tweeter.
SonofSun
plastic penguin:If you go PMC route I would say (given I've heard the DBs) TB2 would be better suited for rocky-type music. Otherwise I'd look at Dynaudios - all Dyns really are party animals.
Cheers PP, I will keep my eye out for used Dynaudio's, and yes the TB2's would defo be worth a punt.
SonofSun:
Just seen these. They are slightly over budget but saves the pressure of bidding on auction sites.
http://www.dub-central.co.uk/products/pmc-tb2i-compact-monitor
shooter
210
SonofSun:
A good listening test to do, but the TB2+ are the next model down from your floor standers and a £500 difference. The Dynaudio Focus 110A could be interesting!
SonofSun
shooter69:SonofSun:
My reasoning is that floorstanders are probably more expensive to produce (more construction materials), so they are probably not really that different, quality wise. The TB2's have the bigger driver, which does interest me. I will certainly consider the dynaudio's though, thanks for the tip.
Big Chris
400
What about EB Acoustics EB2s?
Recently pipped the ATC SCM11s in a head-to-head.
Nicely under your top budget too. (Just under £700 inc. delivery)
SonofSun
Big Chris:
Cheers BC, and I believe there is a 30 day money back guarantee, they are on the list.
shooter
210
Ah well if you you want the best (this is subjective) sub 1k stand mount to put against your !.5k PMC then from the current crop the EB's edge it!
SonofSun
plastic penguin:SonofSun:
Cheers, but I don't want to buy new as I would lose money if I had to sell them. Probably keep my eye on the bay.
