Spyder3TV
DJEPSON
73
Hello Everyone
I am thinking of investing in this so that I can calibrate my TV, but my question is - it worth the investment, I have seen it for around £80.
Thanks in advance
Damian
aliEnRIK
92
Its well worth buying the USB calibration sensor, but the supplied software is garbage
You can download free software though which works very well (If no one posts the link beforehand, ill post it when I get in tonight)
Its only worth getting if you can adjust the red, green and blue settings on the tv though
D.J.KRIME
160
The settings RIK is refering to may be labeled under WHITE BALLANCE and I would be very supprised if your Panasonic does not have any.
This it the LINK RIK was refering to and you will find it a very helpfull guide. The free software to use can be downloaded HERE
aliEnRIK
92
Cheers DJ
