stpierre76:Just wondering if the creek destiny would be a good match for the SA1 or would the primare i30, naim XS and 5i be better suited.thanks in advance.. john
Hi John
I've not heard the Creek with the SA1's however all the other amplifiers mentioned work well with the SA1's. If your budget allows then ATC's SIA2-150 MK2 with (amongst its other qualities) class A biasing up to 2/3 output, high current and damping factor also works superbly with the SA1's.
Sugden and MF amplifiers are also worth looking at.
All the best
Rick @ Musicraft
