- Aug 15, 2009
- 19
- 0
- 0
I bought a Denon 1910 receiver yesterday at RS. I now need a set of speakers. The guy at RS was recommending a set of Monitor Audio Vectors. The one thing I would have to change are the rears at they are simply way too big. I am considering the much smaller Monitor Audio R45HDs instead. Total price would be £520. The one thing I didnt check was the sub model (VW8 or R370HD) how much difference will this make?
I know What Hifi reviewed these this month and gave 4 stars against some pretty good competition priced at £900-£1000. Does the price of £520 make these better than say the Q Acoustics 1010 package which is slightly cheaper (again I would have to change the rears due to size).
Would changing the rears as I have mentioned be OK?
They also have the Mordant Short Amumnis at a similar price.
Another option would be a pair of Monitor Audio R90s (£220), a pair of R45s (£150), an R180 centre (£150) and keep my sub (Yamaha SW-P201) for a while.
One point I should mention is that the fronts and centre will be placed on the shelf below my 42" plasma so the L and R will not be far apart unfortunately. There is just enough height for the Vectors. The other point on the Vectors is that they are angled up when sitting on their base.
Speaker choice is driving me nuts. One problem I have is in my areas there are very few dealers and it is difficult to listen to the setups.
Any help gratefully received.
