speakers speakers speakers.
mistersteve
6
Iany thoughtswas wondering if someone could help I need two new floor standing speakers budget of around £600 I'm using a yamaha rx v595 amp usage will be 50/50 split between music and films have tested the dali zensor but seemed to lack a bit of bass for my liking I'm going to the bristol show next month but probably won't be able to test speakers properly there hopefully grab a bargain thoughts would help thanks.
goalhanger
34
What about Tannot DC6T for £539 in espresso from exceptional-av.
I have Rega RS5s which I have used with Yamaha av amp but they are tricky to position if you can't get the side clearance. I might have gone for the tannoys if they'd been that price then. Colour would have been a better choice for missus.
Good luck at the show.
goalhanger
34
jonathanRD
179
52
18,670
Ideally demo at home, only then will you know how they sound in your home.
Also try Monitor Audio BX5 or BX6 and Q Accoustics 2050i.
I home demoed Rega RS3's and the Tannoy DC6T's when the Tannoys were £699 (RS3's were £780).
On balance the RS3's matched my amp better and were more musical, but the Tannoys felt like they wanted to party :dance:
Had both sets each over a weekend, this is the best way to demo speakers before you take the plunge.
mistersteve
6
Thanks for that will try to find some local stockist for these speakers . didn't know they would let you try them at home.have thought about these before.
