Speakers cables
Hello, I am planning to buy QED Silver Anniversary cables for Monitor Audio BX2's. I have no idea which buy because there are for example bi-wire, wire.
Regards
I want silver anniversary, but I don't which is suitable for speakers, bi-wire or wire.
It's the same wire, so the only question is whether you want to bi-wire the speakers. WHF's review suggests it's not worth doing but it's entirely your call.
Thanks for replays.
MUSICRAFT you saved me one more time, thanks to you.
Regards
Hi Eargasm
Firstly i'll recommend that you single wire the BX2 speakers.
Secondly standard 79 strand OFC speaker cables (which you should also be able to pick up from local elrectrical stores for very little money) will be more then good enough for the UD-M30 and BX2 speakers.
All the best
Rick @ Musicraft
