Speaker switch...any good?
Hi. Has anybody tried using a speaker switch to add a pair speakers on their av amp? Can I connect this speaker switch on the center channel of my av receiver? Thanks.
Yes. Using only one av receiver I will connect the speaker switch box to either the front L&R or is it possible to connect it to the center channel because I have a spare center speaker that I want to use simultaneously with my existing center speaker.
it is safer to connect only one speaker to each source, with accordance to its impedance. i'm afraid that the switch you want to use will damage your system. using banana plug is more proper switching method and very convenience.
