Speaker recommendations on a £500 budget.
At the moment my system is Cambridge Audio 640A Version 2, Cambridge Audio 640C Version 2 with Monitor Audio BR2 speakers.
I have £500 to spend on some new standmount speakers.
I also want to know if i need to upgrade my speaker cable for these new speakers. I have CAMBRIDGE AUDIO SYMPHONY 400 at the moment.
Any comments are much appreciated.
Just buy new edition of WHF.
Starkey:
Hi Starkey
You should also consider Dynaudio's superb DM 2/7.
http://www.whathifi.com/Review/Dynaudio-DM-27/
I would decide on the speakers first. Once the new speakers are settled in than look at possibily of changing the speaker cables.
Rick @ Musicraft
Id go for one of the following
Bowers and Wilkins 685s,
used neat motives 3,
Used spendor S3E
deal on EPOS m12i
These are the speakers ive owned/heard and i thought were excellent. Demo as much as you can to see what you like.
Thaiman:
Klipsch Icon Wood WB-14
WOW, they are some lovely looking speakers. Have you heard them Thaiman? Is there a review anywhere?
Rega RS1's, AVI Neutron 5's and the EB Accoustics EB1's should be on your demo list.
Big fan of Focals. The Chorus 806V are around £500. I'm using them as rears in my setup and they're brilliant. For some strange reason, WHF rarely test Focal. Do a search on the 'web, there are a few reviews around inc. this one for the more expensive 807V.
