Looking for advice on speakers to be used in an 11x15 foot room, with solid plaster walls and carpeted floor. The speakers would be placed against the long wall, either side of the TV (about 4 feet apart), firing across the room. Distance behind the speakers would be limited to about 8 inches.
I dug out a pair of Leema Xones I had in storage which I thought might work but the overall sound was too lean. The top end was fine being clean and smooth which worked well with the openness of the amps and didn't sound sibilant at all but I'm after something with a fuller sound (but not too big so as to be boomy).
They'd be used with a Marantz CD17KI mk2 and a Plinius M8/P8 pre/power. Budget, say up to £1,500 new or used, floorstanders or stand mounts.
So, any recommendations for a potential short list?
