Speaker mounting
F
FunkyMonkey
My years old Tannoy DC1 speaker mount says it needs an Omnimount bracket to wall hang.
Well I can't find an Omnimount with correct screw holes.
Are there any discreet brackets strong enough to hold 10kg of speaker whilst allowing me to swivel both horizontally and vertically by a few degrees?
F
FunkyMonkey
Thanks, but I prefer a mount that is not visible from the front.
macdiddy
87
You could try searching on amazon or ebay for suitable brackets, but looking at a picture of the DC1, thats one bulky and heavy speaker you are trying to mount, hope your walls are strong enough.
F
FunkyMonkey
It is an outer wall. The screws will go into dabbled plasterboard that sits on breezeblock walls.
So no worries about fixing as long as I use long enough screws!
