Speaker Cable Suggestions for Audiolab 8200A
gareth133
18
I have an Audiolab 8200CD and 8200A amplifier. I am currently using Usher S520 speakers. Due to a recent re-shuffle of furniture in the livingroom I need new speakers cable.
The cables will have to be around 9m in length to run under the floor from the amp to the speakers.
Can anyone suggest speaker cable that would work well over a distance of 9m and with the Audiolab/Ushers?
Thanks,
Gareth
Use the ones the pros use, Van Damme. If they're not exotic enough, there's the Dynaudio OCOS cables especially designed for long runs. Comfortingly expensive so must be good
