Speaker Cable Home Cinema
lbafsaj
67
Just setting up my new home cinema system and have QED Rev Signature cable for my fronts and will use same for the centre. Finances will not support running this for rears ( prob 20 mtrs reqd) , so what effect (if any) will there be if I go for a budget QED cable ? My logic states that the auto setup on my receiver should take care of any sonic differences ? Am I wildly out here ?
Any thoughts please,
The view I took is that the rears are mainly for ambient sound so I put QED silver anniversary to the front and cheaper to the rear
Ooops, typo
As a rule of thumb, you're much better off with a quality speaker cable on the fronts than the rears as most soundtracks are front heavy and the majority of dialogue is centre driven and music L/R driven. As suggested the rears are for effects and ambient sounds. QED Signature Revelation is a very good cable for L/C/R - you could use either QED original or even QED Micro on the rears which is a little less expensive.
I've got QED micro on the rears as I had to thread them up through a stand to the Kefs. I have to say I'm happy with the results
QED micro will be a good option for the rears - same brand as the fronts so a similar family sound (if such a thing exists).
You are not going to be using the rears for 2 channel music listening which is where a spotlight shines on a system's performance the most. Also as others have said the rears are ambient and only a small section of the audio mix.
in reality actually you're better off with better speaker cable for the rears ... well certainly thicker anyway
not that any of us actually do this
but the longer the run the more critical the cable ...
Buckshar:
Agreed (Sort of), but the rears dont matter as much as theyre behind us and only carry surround effects. The vast majority of the detail comes from the fronts.
chudleighpaul:Are we getting into another cable thread? (Rubs hands with glee!)
c0pperhead:
Of Can A Worms. Now rearrange .
Hope not! I'm sure we can all agree though you can have a lesser quality speaker cable on the rears (or with my glass half full hat on, a better quality speaker cable on the fronts) as a proportion of your cable budget. QED revelation signature is a great cable so you've chosen well for the fronts. Micro is ideal if you want to tuck it under the carpet, otherwise QED original is a good choice for the rears.
