SoundXtra Small Universal Desk Stand for Speaker
gasolin
BANNED
Anyone who tried the SoundXtra Small Universal Desk Stand for Speaker and can tell if they make a difference? My130mm isoacoustics stands are stil a bit to big
Hi Gasolin.
I use the soundxtra speakerstands with my Argon Octave 5 on my bureau. I've used extra felt-tape under the stands to isolate them from my bureau. It's not always enough but that mayby to blame to the simple speakers I use or the volume I play sometimes with music or film (Massive Attack with Angel or Star Wars part 7)
The stands are handy because they are 'a big hinge' and they are firmly build. (sorry for my english)
Have tought about blue tack under the stands, some speciel foam feet between the stands and speakers if i buy them
Other than expensive atacama SL200i and isoacoustics stands (almost half the price of the atacama SL200I stands) i find it very difficult to find good "small" stands for less than 100€ for small speakers like q acoustics 2010i/3010 2020i,3020, dali pico, wharfedale diamond 210 and other small speaker
Might either of these help?
I used the smaller DS1 with my desktop speakers and they were excellent.
Essentially a nicely shaped block of 'rubber' type material that isolated the speakers nicely. Check the dimensions to see if your speakers will fit. Only £25-30 pr.
You mean
Audioengine DS1 Desktop Speaker Stands
These work a treat. I can recommend them highly.
