i listen my music through the denon1909 and i love it but a friend came round and that it sounded to warm and relaxed, he said the M/A br5's are great but safe and he said without being 100% sure that the denon1909 would be on safe side. He then said i should put my br1's at the front use my old tdls same size as br1's as rears and buy a stereo amp.I have a C/A 640h which has been said that is on the bright side.I have been told to upgrade my £2 per metre cable to some qed silver stuff as it will help against my warm sound.
The main problem is i will only have about £150 pound to spend in about 5 weeks,what is better for sound a graded C/A 640 stereo amp or a second one off ebay. You can pick up a arcam alpha 8R or 9 for around 150-200 they are about 8 years old are they any good still.
