SOUND OR VISION?
tvspecv
156
which would you consider to be more important in home cinema
that HD picture or that sharp deep bass sound?
Psychologically, vision always takes priority over hearing, so an attention-grabbing picture can mask a multitude of audio sins.
That's why those of us who do this for a living tend to assess the audio capability of AV components with the display off.
Oh, and there's much more to good sound than 'sharp deep bass'
Initially I moved to Bluray because I was sick of edge enhancement and (visible) video compression. I wasn't expecting the difference in audio that I experienced. So I would say both are important, but I would err on the side of video, as that annoys me the most.
Also, I would say that the size of the audio soundstage needs to match the picture size - a projector just doesn't match with an all in one 5.1 system, and a 32" screen doesn't go with a top notch audio system. It's just so much more engrossing and believeable when the size of the audio matches the video.
For me it is the sound. and the sooner that the BD standard includes HD sound as the minimum requirement for the main feature it will be a better product than it is.
David
Life would be much simpler if you had a link to your Facebook page in your bio. Then you could say 'see our bio for link'
