Sound Level On Blueray
motley
202
I have a Sony bdps550 linked through my Sony Z4500 LCD TV but when you play a Blueray disc you have to really crank up the volume on the TV which you do not have to do when playing a normal DVD?
Not a lot you can do about that
Blurays are designed to be used with av amps to make the most of its 'dynamic range'
Still ~ have you tried going through the various settings on your equipment and perhaps any 2 channel options within the bluray disc itself ?
i have the same player but a samsung telly, and have the same problem, i watched grand torino last night and had the vol on 60, whereas i watch normal telly on about 15-20.
Try the following........
Press HOME on the tv's remote to call up the menu:
Navigate to settings:
Navigate to sound:
Change " Target Input" from "Common" to the input used for blu-ray ( HDMI 1 or whatever ):
Scroll down to " Volume Offset" , and increase from 0 to a plus figure ( say + 4 or whatever ):
Now the volume for that input should be increased , so you shouldn't have to crank the volume up as much to get adequate sound levels , while leaving the dynamics unchanged. Works for the w5500 model so should be the same for the z series!
Thanks Irish, that seems to have sorted it.
