Sound & Display Problems- possibly HDMI
smarky
45
In regards to the HDMI some times it gets picked up when i turn say the sky box on, but other times there is nothing there, as if the HDMI isnt even plugged in. And if you try to watch Sky when the HDMI does work and you get a picture, after a while it distorts and the picture gradually breaks down and jumps and stalls and breaks down.
smarky
45
Hi, Thanks i have contacted the supplier and have arranged a new cable to be sent out, the only issue i have is that all the cables are hidden in the wall so i now need to dig out the plaster and remove cables then replace, but then have to fork out the cost to get it replastered!!!
