- Aug 10, 2019
- 2,556
- 4
- 0
G'Day
First post here, I've been buying the magazine for some time now and I've never really found the answer to this so I thought I'd pick your brains!
I've wired up the BluRay player to the STR-1200 using good quality cambridge audio interconnects so I can get High Def sound (the STR wont decode it) and to be perfectly honest I can't tell the difference between the Dolby 5.1 track and the uncompressed audio track on any of the BluRay discs.
The set up is
5.1 system
Sony BDP-300ES
Sony STR-1200
Fronts Monitor Audio 270 Floor standers
Centre Monitor Audio 225
Rears Monitor Audio 180's
Sub Monitor Audio R360
The sub is a bit light for the size of the room to be honest its 4M by 7.5M. The interconnects are a decent Cambridge Audio set, I forget which but the Speaker Cables are all Belkin pure copper stuff, the heavy gauge one.
I've been doing the math on the spec's and it looks like the STR-1200 does 100W at 6ohms, as the Monitor audio speakers are all 8ohm am I right in assuming that I will see a drop in output wattage due to the increased load?
The difference between the Dolby Digital output and the uncompressed audio output is marginal, I was expecting a marked difference in sound quality.
Not that it sounds bad in anyway, I suppose I was expecting the same sort of jump in clarity etc as I see in the HD video.
Has anyone got any recommendations to what I'm doing wrong? Should I buy a bigger, bolder, HD capable amp?
Any help would really be appreciated.
Andy
The set up is
5.1 system
Sony BDP-300ES
Sony STR-1200
Andy
