- Aug 10, 2019
- 2,556
- 5
- 0
Hopefully someone knows the answer to this. I have a Sony DAV-DZ680W with S-Air wireless rear speakers. It uses EZW-RT10 transmitters which you plug into a port on the rear amp (TASA100WR) and the DVD player. I've stupidly (having read lots of info and missed a key detail) bought a Sony STR-DN1000 AV amp which also supports S-Air wireless rear speakers. I have other kit and want all of fed through the multiple HDMI ports on the amp and a single HDMI to the TV, hence the amp as well as the existing surround sound DVD player. Upon getting the amp out of the box I discover Sony in their infinite wisdom have fitted a different socket for the S-Air transmitter EZWT100 and my existing transmitter won't fit it. Thank Sony for labelling everything as S-Air compatible and then building multiple versions of it.
1. Does anyone know if there is an adaptor to make the transmitter fit the new socket?
2. If there isn't an adaptor are the two different types of transmitter even compatible - i.e. in the USA it is possible to buy the new transmitter on its own, but will it communicate with the old receiver in the surround amp.
3. Anyone know if its possible to buy either the adapter or EZWT100 transmitter in the UK, otherwise I have to get a friend to buy it and post it to me which will take a few weeks!
Sorry for lots of model numbers etc!
Thanks!
Thanks!
