There is no mesh with one player. Its point to point. Same as Wifi.bigboss said:That's why I've suggested Sonos Boost to be connected to the router to create the mesh.andyjm said:Well yes, and no. Sonos uses a Mesh network, with each Sonos box forming a node in a net. Each box then tries to find the most robust route back to the source, either directly, or indirectly using other Sonos boxes as relays. For a multi box system, this results in a more stable implementation with the boxes chatting amongst themselves.bigboss said:Sonosnet is far more robust than WiFi. Connect a Sonos Boost to your router.
For a one box setup as the OP proposes, the Sonos Mesh network can't form. As the Mesh network is really just a protocol sitting on top of standard Wifi cards at standard power, for a single hop, the Sonos Mesh has no more range than standard Wifi.
https://sonos.custhelp.com/app/answers/detail/a_id/3046/~/choosing-between-a-standard-and-boost-setupandyjm said:There is no mesh with one player. Its point to point. Same as Wifi.bigboss said:That's why I've suggested Sonos Boost to be connected to the router to create the mesh.andyjm said:Well yes, and no. Sonos uses a Mesh network, with each Sonos box forming a node in a net. Each box then tries to find the most robust route back to the source, either directly, or indirectly using other Sonos boxes as relays. For a multi box system, this results in a more stable implementation with the boxes chatting amongst themselves.bigboss said:Sonosnet is far more robust than WiFi. Connect a Sonos Boost to your router.
bigboss said:https://sonos.custhelp.com/app/answers/detail/a_id/3046/~/choosing-betwe...andyjm said:There is no mesh with one player. Its point to point. Same as Wifi.bigboss said:That's why I've suggested Sonos Boost to be connected to the router to create the mesh.andyjm said:Well yes, and no. Sonos uses a Mesh network, with each Sonos box forming a node in a net. Each box then tries to find the most robust route back to the source, either directly, or indirectly using other Sonos boxes as relays. For a multi box system, this results in a more stable implementation with the boxes chatting amongst themselves.bigboss said:Sonosnet is far more robust than WiFi. Connect a Sonos Boost to your router.
Yep, have a close look at the diagrams. Using a boost at the same location as the router, and then using only one player is point to point - same as Wifi.bigboss said:bigboss said:https://sonos.custhelp.com/app/answers/detail/a_id/3046/~/choosing-betwe...andyjm said:There is no mesh with one player. Its point to point. Same as Wifi.bigboss said:That's why I've suggested Sonos Boost to be connected to the router to create the mesh.andyjm said:Well yes, and no. Sonos uses a Mesh network, with each Sonos box forming a node in a net. Each box then tries to find the most robust route back to the source, either directly, or indirectly using other Sonos boxes as relays. For a multi box system, this results in a more stable implementation with the boxes chatting amongst themselves.bigboss said:Sonosnet is far more robust than WiFi. Connect a Sonos Boost to your router.
I used net share too with my powernode. In essence, inside the bluesound control app you have to go to net share settings, and type in the IP address of your Nas. Once done, the bluesound will map your nas drive , including album art and you can control playback from the bluesound app itself. Though I never tried bubbleupnp. For more details you can post a query in the bluesound forum, if that is the only thing stopping you from getting one.johnnyboy1950 said:The bluesound pulse 2 is what Im refering to. I read somewhere that you have to set up a "netshare" what ever that is. If it doesnt use DLNA then Im assuming software like
Bubbleupnp wont be able to see the speaker.
Johnny,johnnyboy1950 said:The bluesound pulse 2 is what Im refering to. I read somewhere that you have to set up a "netshare" what ever that is. If it doesnt use DLNA then Im assuming software like
Depends on what you ultimately want from your system. For me, I have Sonos in all my rooms (6 in total). I've had Sonos since 2010 and all its players are still fully supported by Sonos. It's given me hassle free performance over the years. In one room, I've connected Sonos Connect to powered speakers and in the other, I've connected Sonos Connect to my AV receiver. People can also get a Sonos Connect Amp and use with passive speakers, so they're not limited to one box options only. CD is a dying format; I haven't bought one in 4 or 5 years.johnnyboy1950 said:So I cant imagine why anyone would pay significantly more for equipment that sounds inferior and has less functionality.
Local boy then John? Happy for you that you found something that exceeded your expectations and at the right price.johnnyboy1950 said:Ok so today I got to audition some gear at Sevenoaks Hifi in Witham.
Sonos caters to a different need than conventional setups. Of course there will be differences between one box solutions and 2 stereo speakers. Sonos Play:5 as a pair in stereo mode is excellent, obviously comes at a price. Sonos Playbar is excellent, but you can get better for the money if you look at sound quality alone. But for what Sonos does (multiroom), it's amongst the best in business. As I've said few times in this thread alone; really depends on your needs. You weren't looking for multiroom, so Sonos isn't the right product for you.johnnyboy1950 said:I wasn't dissing Sonos in particular. Dont forget Im not looking at a multiroom thing right now. But i cant get past the fact that on a one to one basis the conventional all in one box and a pair of speakers for much less money completley trounced over all the wireless speakers I listened to, even the Naim Mu-so Qb. WHF are giving a lot of these wireless speakers 5 stars, and none I have heard come close to conventional setups that sometimes get 4 stars or less and cost signicantly less. I have struggled in the past with some of the reviews on WHF and what they are really trying to convey but this is the first time I can say "YES I CAN HEAR THE DIFFERENCE".
