Hi folks. I didn’t know where to post this, but thought hifi would make more sense. Anyway...
we are moving to a bigger home soon and I’ve always wanted speakers in various rooms that can all be controlled by 1 device. I’ve been looking at Sonos and it seems very impressive. Now thing thing is what ones to get? Is Sonos ones good enough for a normal sized room or would a Sonos 3 or even 5 be better? I’m after a speaker for the kitchen, the bedroom and the living room and something where I can also listen to music outside.
As for the living room, I also need to buy a new soundbar, so I was thinking maybe buy the Sonos sound bar and sub for the living room and that could be my speaker for in there. Or would you recommend buying a cheaper sound bar and sub as the Sonos sub and bar is expensive, and then buying a Sonos 3 or 5 for the living room instead?
ive also noticed that even tho they call Sonos “wireless”, it really isn’t as has to be plugged in to the wall? Is this correct? Bit annoying that as not sure how I can just take a speaker outside without using an extension cable. Bit annoying that.
Anyway, any help would be appreciated on any Sonos advice. Thanks
