- Aug 10, 2019
- 2,556
- 5
- 0
Current set up is as follows.
Marantz CD 6000OSE KI Sig, Rotel RC 970BXII and RB 971, Kef Q4 (also run my PS3 into the Rotel).
Generally this is a clean-sounding system, but has always seemed rather thin (perhaps due to the Q4s not really having much in the way of bass weight).
Anyway I am looking to update and veering towards including a Sonos in the system, but I am not sure what else to do.
Clearly the simplest option is just to introduce the Sonos and run it into the amp and continue as before, but it would be good to try and minimise boxes and so on.
So herein lies the quandary:
Do I get a Sonos package including the amplified section and use that to run my current speakers removing the Rotels (keep the CDP); or
Use the amplified section in the kitchen with a pair of small wall mounted monitor speakers, and use an additional non-amplified Sonos unit in the sitting room with some new active speakers, or entirely new amp/speaker set up (or keep the Rotels into the KEFs)?
Do I forget all this and do something else?
I am open-minded and whilst budget is not limitless am willing to consider any reasonable solutions.
Thanks in advance for any suggestions.
