Hopefully set-up will be easier than what I am currently going through with my Arc........and WHF are still pondering.
Whatever, I have just upgraded my broadband that required a new router. Can I get my Arc to be recognised..... No.Should be, they regularly update the app and Android is now given equal Trueplay status - though that seems to be because it's using the Arc Ultra's internal microphones instead of your phone's.
It cannot even see my speaker let alone let me change anything in settings.Easiest thing to do when replacing a router is to just change the SSID and password to that of the previous one.
Then all your devices will just automatically connect to the new router
I see, thanksNo, no... You change the SSID and password of your new router to match that of your old router, you then don't need to mess about with any of your devices they'll just automatically connect to the new router
