Software update for Humax PVR 9200T
kitkat
162
Last night my Humax software was updated and I seem to have new features etc but no way to find out what they are or what has changed I have looked at the Humax web page but this is no help, can anyone explain what new features I may have and how to use them. Thanks
Not really sure of them all but here are some:-
(1) Series Link (although you can't use autopadding with this so I am not using it I'm afraid in case I miss the beginning or end of a programme!)
(2) Addition of 32X fast forward and rewind which is handy.
(3) Faster EPG upload
(4) Bug fixes but not sure which.
My Humax froze for the first time in ages last night. Hope it was a coincidence and nothing to do with the update!
Thanks for that, but how do you use the series link, I have set it to record say CSI in the normal way but it only records that 1 and not anymore in the series.
What channel is that on?
If the prog is available on series link then a message should appear letting you know and asking whether you want to record the whole series or just the one programme.
You need to turn off autopadding first though.
[quote user="Scotsgirl"]What channel is that on?
[/quote]
I set it to record a series - Dora the Explorer 🙂 - and then changed the padding. It works just fine. So possibly turn off the auto-padding, then select the series to record, then turn the padding back on. I've not checked whether you get the padding on the series record to be honest, but the auto-pad doesn't cause problems for any series already set up.
You can't use autopadding with Series Link. You have to have the start and end times set to "On time" to use the Freeview Playback 2 features.
Programmes that are shown in darker blue in the EPG are those that can be series linked.
At the moment, BBC, ITV and 4 suite of channels are the only ones to reliably transmit the data. Some other channels may do. Five definitely does not, which is why CSI didn't link.
Release Notes
PGXTF 1.00.21
- Resolved consecutive recording function while
using ChasePlay
- Resolved Schedules staying in the list when
using Auto-Padding
PGXTF 1.00.20
- Freeview Playback - Group 2 (www.freeviewplayback.co.uk)
- Series Recording
- Alternate Instances
- Split Recordings
- Improvements to Freeview Playback Group 1
- Guide available while playing back a recording
- EPG populates while playing back a recording
Note: Freeview Playback functions are not available
when you use Auto-Padding (Early Start and Late
End Times).
Previous Version
PGXTF
1.00.15
[*]Freeview Playback - Group 1 (www.freeviewplayback.co.uk).
>> For details on the Auto Tracking feature,
please download the Addendum
(Auto
Tracking feature (click)
). [*]PIP in playback using space has been resolved.
[*]The loss of schedule after FIND function used
also resolved.
PGXTF 1.00.10
[*]Increase schedule timers to 50 [*]Increased EPG view to 5 programmes [*]Day of the week displayed in the EPG [*]Weekday (Mon-Fri) and Weekend(Sat-Sun)
added to the Repeat Modes [*]You can now use the Left/Right arrows to change
the Start and End times when setting up a Manual
Reservation. To enter the times using the Numeric
buttons press OK. [*]Increased FIND search results to 250 [*]Info "i" button displays programme
info in Schedules list [*]Info "i" button displays programme
info in Recorded Programme menu when Early Start
Time is set to "On Time"
Note: If you have set The Early
Start Time in the menu then you will receive
the info for the previous programme[*]You can Organise your Scheduled Recordings
by Date order (Ascending & Descending) and
Alphabetically [*]The Recorded Programmes menu and Playlist
will display the most recent recordings at the
top of the list. [*]You can Organise your Recorded Programmes
Alphabetically - via the Recorded Programmes
menu and the on screen Playlist [*]Increased Schedule list to 5 displayed on
screen [*]You can mark and delete Multiple Schedules
[*]You can mark Multiple Recorded programmes
for playback and deleting - via the Recorded
Programmes menu and the on screen Playlist [*]PiP (Picture in Picture) now available when
playing back a recording [*]PiP (Picture in Picture) now available when
recording
Note: PiP is limited when recording
to the Multiplex(s) you are recording[*]Playlist and PiP Channel List now available
in the Group window [*]Editing Recording is now renamed to TRIM and
functionality changed [*]Fast-Forward & Fast-Rewind buttons can
be used in the EPG to go forward and back in
2 hour intervals [*]Jump & Instant Replay buttons can be used
in the EPG to go forward and back in Days [*]Jump function now available in 120 seconds
? option available in the Preferences > Miscellaneous
Settings menu [*]Source button problem resolved
For details on the channels please download the
Addendum (click
here to download
). After downloading
the software it is recommended that you carry
out a Default Setting in the Installation menu,
then re-enter any Schedules.
Note: No recorded programmes
will be removed when you do a Default Setting
however your schedules, favourites list, and menu
settings will revert back the default values.
Note: After upgrading to the
latest software you may have occasions where your
Schedule list appears blank, to resolve this press
the Down arrow.
PGXTF 1.00.08
1. Resolve screen blanking problem
2. Resolved Text/Interactive functions not working
after several hours on a channel
3. Improved Auto-padding function
4. Improved schedule function when not using Auto-padding
5. Resolve problems when PVR thinks that a tuner
is being used for recording
(PiP functions not working)
- requiring a reboot
Note: If you have set the Recordings Start Time
option set in the Record menu (so that scheduled
recordings start early) and you make an Instant
Record on the programme directly before your schedule
(on the same channel), then the schedule will
not take place as the Instant record will take
priority.
Updated manual:
http://www.humaxdigital.com/uk/update/List.aspx
