Small room, big speakers.
Will
I've temporarily moved the hi fi into a very small room - 3.5 meters x 2.5 meters. It'll be there for some months (CM10 speakers, Linn amps). It's no surprise that the bass is boomy nomatter what I've tried to do.
Would there be a low cost solution to the bass problem? What are foam bass traps like, any good? If so, which ones?
Will said:
I've temporarily moved the hi fi into a very small room - 3.5 meters x 2.5 meters. It'll be there for some months (CM10 speakers, Linn amps). It's no surprise that the bass is boomy nomatter what I've tried to do.Would there be a low cost solution to the bass problem?  What are foam bass traps like, any good? If so, which ones?
Have you tried a sock in the ports?
I used to have some B&W CM2's and I too have a small listening room, afraid I had to change the speakers... Base traps perhaps, as a temp measure I tried putting some pillows behind mine and the base still boomed.
Good luck.
Mac
www.macsmusic.blogbubble.net
Obviously a Linn has no tone controls, and they are big speakers with prodigious bass output. But you could buy a cheap graphic equaliser, or an amp with tone controls to use pro tem or insert if you have a spare output/input or tape loop.
chebby said:
A pair of good, cheap bookshelf speakers from ebay for a year. Then flog 'em for what you originally paid after you've finished.
This. Or use it as an excuse to spend some money on a decent headphone rig (I'm assuming Linn doesn't give you a headphone output on the amp either).
If you have a second amp, you can split the signal to both amps and this will give you option for attenuation of the lower frequency drivers separately.
I guess an L-Pad in Bi-Wiring configuration would do the job as well, but I like Bi-Amping much better.
If you want to continue using your big speakers and can give them a little space, the DSpeakers Antimode Dualcore is probably the most effective way of controlling the bass.
Not cheap at nearly £700 but will probably get the job done and will always be useful, giving you extra control, even in a bigger room.
However if placement is a real problem in the smaller room, good small speakers such as the Zensor 1 or, at higher cost, the Neat Iota.
How are the speakers split - they're biwireble....yes?
If the top/mid are coupled remove the links - in other words disconnect the woofer.
Just run the mids and tops.
