Small pre-amp?
AlmaataKZ
297
8
18,895
Does anybody know of small-sized pre-amps with balanced outs, remote control and ideally a home theater bypass?
A variation would be as above but with a built in DAC?
You may still be able to find a 2009 pre (+) model either ex demo or end of line.
Small changes only for 2010 model.
Bel Canto pre3 has XLR outpouts but I'm not sure it has AV bypass.
angelface59:Bel Canto pre3 has XLR outpouts but I'm not sure it has AV bypass.
Its manual states it has "Home Theater Bypass mode on Input 5" - which sounds pretty much like AV bypass to me.
Thanks, gents. Bel Canto looks a candidate, I beleive it is about 1800.
Loosk like the choice is quite limited if trying to fit all the requiremtns in (small, balanced out, bypass, remote).
Which full-size pre amps can you recommend (balanced out, bypass, remote). Budget 500-1500.
ATC CA2 at about 1000 is a possibility. Which others are worth looking at?
