Sky + without subscription question
I am asking this on behalf of a friend.
He has one of the older Sky boxes which bought from Sky as a one-off buy (no subscription). He wants know if he buys a second hand Sky + box, will he be able record those free channels without having to get subscription whilst if he uses his current card?
Hope this makes sense.
Thanks Dave for the prompt response, I take it they disable the recording via the card?
You work for Sky don't you?
kevin_m:
Thanks Dave for the prompt response, I take it they disable the recording via the card?Sort of yeah,In that by default the "+" facility is disabled on Sky stb's and then enabled when you subscribe.But yes it's all done by the viewing cardkevin_m: You work for Sky don't you?
No not directly.I run a small independent Aerial and Satellite business. But i/we do installation's on Sky's behalf as Sub-contractor's amongst other thing's!
