Mr Strapped, all points good and entirely taken in, and indeed you are right in pointing out that every post nearly always expresses an opinion. Still, the impression given to me by the aforementioned salesman was that I was more than slightly mad questioning whether I might opt for anything other than full 1080p, regardless of circumstances. Indeed, I felt compelled to ask him if full HD might mean being able to access some secret quality TV programming the existence of which had entirely escaped me until now. Alas, the answer was that I would still get the same derisory programmes, just 'bigger and better', and I cannot see myself ever wishing to opt into that. I feel I should re-state, first, that it is not possible, at least at present, to purchase a 1081p television that has not at least a 26" screen, and that I am informed that this will not change in the future. Second, I beg to differ with your opinion that the difference in the cost of 1081p equipment compared with SD equipment is so small as to make the choice a 'moot point'. It might be the case in years to come, if only because SD equipment will cease to exist, but right now the difference is actually considerable. The cost of a 22" Samsung TV compared to a 26" Samsung is over £150, and the difference between a Humax SD PVR and the new HD Humax PVR will be also be over £150 when the time comes, not including the fact that SD equipment will inevitably be discounted. So the actual difference will be an extra £300 on an intended outlay of £380, which I make to be almost 93% or almost double the cost, at least as far as the kind of equipment I would want is concerned. Of course you are right, if I were someone who watched a lot of sport, and watched in a bigger room, then full HD would be a no-brainer, but we are fast approaching a time when SD equipment will become very cheap, precisely because of the transition to HD, and for the likes of me, and I suspect large numbers of others, there will be some real bargains out there.
