CJSF said:No text . . . wonderful, try again?
The_Lhc said:It'll work fine, don't worry about it. You won't be able to record any longer though, so if that's important you will need to get a freesat recording box.
daveh75 said:It you cancel within the 30 day cooling off period, Sky will usually want the box back, you keep the dish though. The point The_LHC was making is, is that recording on a Sky box requires an active subscription, so when you cancel you lose the function to record, and access to any programmes that you've recorded.
