Question Signal feed for a large OLED TV
Venger
29
26
70
Back in the day, well 30 years ago, I considered myself a hi-fi nerd par excellence, devouring What Hi-Fi each month, clued up on all the model numbers and tech of the day whilst spending rather large sums of money (well large for me) on my two channel hi-fi system over the years.
Today I must be considered a dinosaur!
The last TV I bought new was a Loewe 32" CRT back in the early 00's, when that finally died, having very little disposable income and utilising the archived awards info on the website here, I bought a second hand Panasonic TX-32LZD85 on eBay for £60 and that has served me very well.
However, having spent Christmas with family who have an absolutely huge TV, coming back to the Panasonic takes some adjusting to so I have decided to source something much larger on the second hand market, something along the lines of the LG OLED55E9PLA for example.
What I'm interested to know is are these modern, large panel OLED tv's fussy about the sort of signal you feed them? I don't have Sky or any subscription TV services, I just use a Manhattan T3-R Freeview box. Is it ridiculous to think that a TV of that quality will perform anywhere near its best when fed from a Freeview box like that?
I live in East London and do benefit from very strong TV signal reception.
Is there anything else I should consider about OLED's and/or large panel TV's in general before parting with any cash.
Many thanks for your time.
We only have Freeview and Freesat for live TV viewing, and the HD channels look perfectly respectable - if your Freeview box isn't HD, you'll want to think about getting a new one. Does the set have iPlayer built in? I ask as some stuff (Attenborough, some sport) is available in 4k/HDR. A good TV looks at its best when fed with a decent 4k blu ray, but just fed with HD stuff it should still be a big step up.
Second hand OLED TVs may well possibly have screen burn/image retention on them, especially the older ones. QLED or LED/LCD TVs won’t have any screen burn. I would keep clear of plasma TVs too. If you bought a new OLED TV that would serve you well just as long you keep away from news channels and only watch them for short periods. What’s your budget?
It's definitely worth making sure a 2nd hand set doesn't have any screen burn, but I think it's a story way overplayed now. My daughter games a great deal with our 65" Panasonic plasma, which means lots of static images, and there are no issues at all. My brother is also a keen gamer, and has no issues with his OLED after five year or so.
So yes, be careful in buying (though you should be doing that anyway), but don't be put off OLED because of the overplaying of this particular card.
Many thanks to you both for your replies.
I can remember when screen burn was talked about a lot back in plasma days, tbh plasma wouldn't be on my radar now but I hadn't considered screen burn in modern tv's.
Since posting I have opened the obligatory can of worms by Googling OLED vs QLED and don't really know what would suit me better.
Are LCD tv's still being manufactured?
In terms of budget, probably something around £300 perhaps.
The Freeview box I have now has the HD channels 101-105 and also has access to iPlayer and I would potentially consider getting a secondhand blu-ray player as well just to make the most of the new tv.
There is a LED LG TV here for £300 at John Lewis with a 5 year warranty that could be an option for you:
TCL make some affordable QLED options too, although they don’t tend to come with a 5 year warranty unless you buy from Costco. Samsung have LED options too and yes, I believe they still make LCD TVs.
If buying a second hand OLED I would purchase from a shop if possible, that way you can return it if anything is wrong with it and you should get some sort of warranty with it too. I will keep looking for different TV options. 👍
QLED TVs tend to be quite bright TVs with good blacks and the OLED TVs have even better blacks but may not be as bright.
Reactions: Venger
Many thanks for the info R2D2, much appreciated.
I can't quite believe you can buy a brand new LG 50" tv for under £300 !!
I've spent a couple of hours this morning looking into the different screen tech, adding QNED and QD-OLED into the mix to further complicate things.
The room the tv will go in has very large bay windows at one end so when the sun does decide to shine, the room can get a lot of light which makes me wonder whether an OLED will be bright enough (even now we pull the curtains when it's really bright if we're watching tv).
The only thing I don't like the sound of about QLED is their off-axis viewing limitations.
I have gone from OLED to QD-OLED because of the sun in my room. Mind you you can buy OLED TVs with anti-reflective coating but the ones I know that work best are Samsung TVs and Philips TVs. I am sure some of the other manufacturers are good too though. You can check on this website:
I actually don’t think manufacturers do make LCD TVs anymore!
I know you're tongue in cheek, but just for clarity, all televisions are LCD, aside from plasma and OLED. The sheer number of acronyms out there makes it a nightmare for anyone who has been out of the TV buying game for a few years far more complicated than it needs to be!
Many thanks for the continued info R2D2 👍
I am on avforums from time to time, hand't thought about their classified ads, will take a look.
Reactions: Gel Man
Or if you just purely want a 4K Blu-ray player for your TV and are not bothered by the lack of Dolby Vision this is a top deal too:
All 4K Blu-ray players produce similar pictures, so there is no need to spend a fortune on one.
Gets 5 stars from WhatHifi:
Reactions: DougK1 and Venger
If you can stretch your budget by £250 you can buy a brand new OLED on Amazon:
I think it would be good in a bright room too. Perhaps just buy a cheaper Blu-ray player, if you need some suggestions let us know. 👍
Perhaps don’t bother with the Blu-ray player and use the apps on the TV for films. You get Apple TV with the TV, where you buy movies for £4 which are 4K Blu-ray like.
Reactions: Venger
Many thanks for the link R2D2.
I've become a bit obsessed these last couple of days tbh, trawling through reviews, looking at eBay and classified ads etc!
I don't think manufacturers make it particularly easy with their model numbers. People in the know tend to just list the brand and an abbreviated model number, Samsung S95B for example but those four letters/numbers are then buried in a load of other numbers and letters to take into account the size, technology and probably country of release!!
I did message the seller you found in your link above over on avforums but haven't heard anything back. I must be honest and say I'd be terrified transporting any of these large panel tv's in my car without the original packaging but not everyone keeps it, my loft is full of boxes for pretty much all the equipment I've ever bought lol.
Reactions: DougK1 and Gel Man
This isn’t a bad deal either:
It’s not fully QD-OLED only the 65-inch TV in this model is, but I will have a non reflective screen.
You can buy feet stands on Amazon for £20 Bontec ones. It has a scratch but that won’t affect viewing. It’s B grade - which is good on there and has a 10 per cent discount code.
I would use a duvet and sheets for transport.
Reactions: Venger
Yes got plenty of duvets and sofa type cushions etc.
I was wondering if a few wraps of pallet wrap or bubble wrap around the actual screen is a good idea or d'you run the risk of damaging something?
Reactions: Gel Man
On the subject of screen burn most OLEDs run a little maintenance program - when you put them in standby - to eliminate any traces of it.
We had an 80+ years old customer a few years back, who out of habit used to switch the socket off after putting the TV in standby, which prevented the maintenance program. In 6 months his set was ruined, massive screen burn from news channel banners at the bottom of the screen.
Our Blackburn shop manager and our Panasonic rep tried for months to get a new TV for the gentleman but Panasonic just kept coming back with "user abuse"
Weirdly the customer himself (or younger relative) after our and the reps failed efforts, complained directly to Panasonic and got a new TV
Reactions: Venger and DougK1
I think with newer OLED TVs it’s not such a problem as the older ones if you look after them correctly. Buying second hand OLED TVs that are 5 years old plus could provide a problem though. Then you have QD-OLED TVs a newer technology so there were reports that they got screen burn after a while too. I think they tried out my one the Samsung S90C and reported it got screen burn after a while, so I am being extra careful with it. If I bought a new OLED TV I wouldn’t be that bothered about screen burn though with such things such as maintenance programs being used on that TV to prevent burn in.
Reactions: Venger
