Looking for an integrated amp in this price point. I run an m-dac into an audiolab 8200p and I'd swap the amp for an intergrated. So I'm looking for ideas intergrated or valve if it's possible.
Excellent tasteThetelecaster said:Music wise I can go from John Coltrane to slipknot
Mark Rose-Smith said:Naim nait xs 1st gen can be had for that kind of cash (used)if you wait for the right moment.....it's a cracking amp that will drive any speakers in that price range....you might never need another.
drummerman said:Mark Rose-Smith said:Naim nait xs 1st gen can be had for that kind of cash (used)if you wait for the right moment.....it's a cracking amp that will drive any speakers in that price range....you might never need another.
Great amplifier.
chebby said:drummerman said:Mark Rose-Smith said:Naim nait xs 1st gen can be had for that kind of cash (used)if you wait for the right moment.....it's a cracking amp that will drive any speakers in that price range....you might never need another.
Great amplifier.
2009 Nait XS here ...
http://tomtomaudioshop.com/latest-pre-loved-stock-23-w.asp
Yep, went from Naim and Roksan to Densen. It gave me everything the other two were good at and more.drummerman said:You may be able to get a s/h Icon Audio amp. Decently powerful for valve amps and good looking imho.
Having said that, the aforementioned Naim is superb.
No problem to have either serviced in the future if need arises.
As a Cyrus user I'm bound to suggest their products too.
Great sound and reliable. Upgradeable (8 series and above) and again, serviceable. Fuller and more fluid sounding than Audiolab.
Not often mentioned ... Densen. Head over to YouTube and although not the ultimate in comparison ... You probably hear how they sound, fantastic. Looks is Scandinavian minimalism, sleek and slim.
A guy on here bought a s/h one recently and loves it.
Good luck
drummerman said:chebby said:drummerman said:Mark Rose-Smith said:Naim nait xs 1st gen can be had for that kind of cash (used)if you wait for the right moment.....it's a cracking amp that will drive any speakers in that price range....you might never need another.
Great amplifier.
Expensive. Seen them go for around £700 a few times.
insider9 said:I would however point out to do your research first and not mess dealers about by buying and returning gear just because you can. Returns are not there for you to have many free auditions
chebby said:drummerman said:chebby said:drummerman said:Mark Rose-Smith said:Naim nait xs 1st gen can be had for that kind of cash (used)if you wait for the right moment.....it's a cracking amp that will drive any speakers in that price range....you might never need another.
Great amplifier.
Did those vendors give a no quibble 12 month warranty?
http://tomtomaudioshop.com/why-buy-preloved-from-us-21-w.asp
Apologies, I meant this paragraph as a general remark or more towards OP or anyone who isn't sure what to go for and casts a wide net.chebby said:insider9 said:I would however point out to do your research first and not mess dealers about by buying and returning gear just because you can. Returns are not there for you to have many free auditions
You are preaching to the choir. I would not dream of shopping in the way you describe above. (I am not called ‘gel’ )
I am actually very tempted by one of the UnitiQutes listed on the Tom Tom ‘pre loved’ page. Grrrr. (I wouldn’t have been ‘exposed’ to temptation if I hadn’t been looking for good used Nait XS mk1s.)
drummerman said:Unless you need the built in streaming or small form factor the XS will be superior to the all in one. The unitiqute may be all you ever need but the XS is close to supernait performance. Add CCA out the back for streaming if needed.
chebby said:drummerman said:Unless you need the built in streaming or small form factor the XS will be superior to the all in one. The unitiqute may be all you ever need but the XS is close to supernait performance. Add CCA out the back for streaming if needed.
I wouldn’t dream of recommending the UnitiQute to the OP.
It just happened to be there whilst I was looking for a 1st generation Nait XS for this thread.
