Sansui WLD 201 Network Player Question
paulsue38
55
This is good value atthe moment around half price. Thinking of getting one. However, in terms of High quality files it only goes to 24/48. I was going to play this through the DAC on my Pearl Lite CD player will this allow the Sansui to player a wider range of high quality files?
If the streaming section is limited to 24/48 – really? In this day and age? – then no amount of dackery is going to change that.
That does indeed seem to be the case - it's 24/48 max for FLAC.
Almost as bad as that Pro-ject streamer that can't play FLAC at all
Yes, it is tempting, isn't it?
I almost was, but plumped for the Pioneer N-30 instead because a) it seemed to have better support for high-res files (though I admit to not being an expert here) and b) there is an Android app for controlling it (I don't do Apple). It costs a few pounds more (about £240 at the moment) but I've had mine for a couple of weeks now and am convinced I made the right choice.
Bought the Sansui in the end got it for £100 on an auction site. I am impressed with this player. It is nicely finished and easy to use . The manual is easy to follow. It scans and finds networks very easily. I have tried with both Wi-Fi and wired home plug connections. F M sounds good for the money. DAB is what you would expect. It locates internet stations well and the sound quality is again impressive. A bit hit and miss when using it to stream from main computer and does buffer a lot on high res tunes, but I don't tend to use this very often. If it is mainly radio that you are after then at the £170 that this is now available for then it is a very good deal.
Paul
Have been looking at this for a while. Just wondered if it will play files above 24/48 Flac, but I appreciate it would only be at 24/48 and not higher. I was looking to play a lot of music from USB stick/portable hard drive.
Thanks in advance
Shaun
