Samsung UE46ES6800 VS Sony KDL-HX853 ???
Hi Guys,
I would be really grateful if anyone could help me to choose the best 46" Tv at the moment.
I want to have the best picture possible. the sopund is not as importtant as it will be connected to receiver.
I can have sony kdl-46hx853 for £1050 and samsung ue46es8000 for £1150.
What would be the best option? Or maybe you suggest something totally different?
Any advice would be appreciated.
Those of you who had a chance to compare this two models to anything else please let me know your thoughts.
My budget is up to £1200 and I would like to buy a TV with the best picture and Skype + you tube funcionality.
I am not fuss about all this talking and gesture functions.
Any help?
It is a pity this one isn't slightly cheaper:
http://www.totaldigital.biz/index.php?main_page=product_info&cPath=43_51&products_id=4770
Hi there I brought the es8000 55 inch the picture is still the best I've seen everybody who comes to my house cannot believe the picture Skype good on it as well I Skype my uncle in oz clear as anything my sister got the samsung 6300 and she happy with that to but the 8000 is amazing tv which ever you choose enjoy 🙂
Can you squeeze a larger TV in?
The Panasonic 50ST60B is within budget. You might even be able to buy 50GT60B with some careful negotiating.
Unless the OP specifically wants an LCD or LED? If a plasma is also possible, then the Samsung PS51F8500 (not sure of its price though) might also be considered, as it is very bright for a plasma.
gotta find someone that stocks the gt60 first!
Thanks a lot for suggestions.
Unfortunately I don't really like plasma's as they are quite power hungry. Also My sitting position would be at about 2.3 metres so I am not sure if anything buigger than 46 would be ideal...
Any other suggestions please?
Any help?
Yes i did compare both of these models you are looking at plus the Panasonic GT50 plasma. I went for the Sony for 3 reasons
1 The picture quality was not far off the Panasonic GT50, although the Panasonic did beat it.
2 The Samsung seemed to have a tad more motion blur
3 Sony was the cheapest of the 3 to run on electricity. Plasma TV's of a similar size use from around 2.5 to 4 times the amount of electricity.
If i were you, i would choose the Samsung for around £1049.95 @ RS simply because you are going to have to buy bits for the Sony to utilise the Skype function.
Regards ...
I'm at 2.4 meters with a 51", loves it
Thank you.. I think that is what I am going to do.... Samsung does looks better as well.
I was just wondering which of these two have a better picture. I know Sony won 2012 award but I am wondering if one of the reasons was the price of os the Samsung S8000 , as it was almost two times more expensive to Sony at one point...
:cry:
erhhmm :? now that doesn't helop.. I am going to start wondering if I should go for bigger screeen...
I think if you go bigger, it will be longer before you convince yourself you need a new TV, so thinking about it a bigger TV will be cheaper 😛
Richer Sounds:
http://www.richersounds.com/product/tv---all/panasonic/viera-txp50gt60b/pana-txp50gt60b
Then a price match with:
http://www.totaldigital.biz/index.php?main_page=product_info&cPath=43_51&products_id=4836
And you are in a budget, with one cracking TV!
This can't be bad too:
http://www.totaldigital.biz/index.php?main_page=product_info&cPath=43_51&products_id=4536
Hi... I am not in rush anymore as someone just boughtmy designated samsung yesterday... ii have foud out Today whe I went to pick it up... you can just imagine my dissapointment.. 🙁( ... but if that happened then I thing it must be a destiny... probably my future is to have better tv than this two in the title...
So I will be looking to get a new best tv with no rush now. .. I will appreciate any firther advice..
Thanks a lot for being so helpful so far...
Have you actually found an hx853 to buy anywhere? I cant find one online. I was hoping to buy an older tv to save money as I only have a small budget. Worth considering... maybe u cant get hold of the hx853 anyway ?
