Samsung LE32B450C
Hi all,
Does anyone have one of the above that would be able to offer me a review, or know of somewhere I can go to find one? Also, I'm a bit of a technophobe when it comes to setting up systems, so I have another question -
My current TV has 2 scart sockets in the back of it, one which is currently being used for my Sky + box, and the other for a DVD recorder I've just purchased. I've noticed that the above model only has one scart socket. Is there any way that I can keep the same set up even though I would only have the one scart socket?
Steve
What DVD recorder did you just get? Does it have an HDMI connection on the back? Many new DVD recorder have HDMI connections which will improve your picture over a scart lead and mean you can keep your Sky box connected via scart. Otherwise, do either the Sky box or the DVD recorder have a component video connection on (3 pins red, green and blue)? You could use that instead also.
