G Greenwich_Man Well-known member Sep 6, 2008 106 32 18,620 Feb 5, 2010 #1 Can you tell me please if the SACD version of the Stones "Let it Bleed" will play on a non SACD Player? Click Here
F FunkyMonkey Guest Feb 5, 2010 #2 Yes it will. It's a hybrid disk. Better still, get an SACD player. ;-)
F FunkyMonkey Guest Feb 5, 2010 #3 Although I don't think that is the SACD edition. Amazon often make this mistake. I think the SACD version is here.... http://www.amazon.co.uk/Let-Bleed-Rolling-Stones/dp/B00006LSTC/ref=mb_oe_a
T the record spot Guest Feb 6, 2010 #4 The SACDs are in digipacks; jewel cases are DSD only. You can pick them up pretty reasonably if you shop around; a lot of independent dealers seem to have them.
U unfocused Well-known member Jun 21, 2009 37 9 18,545 Feb 6, 2010 #5 As The Record Spot says the hybrid SACD's are in digpaks and the redbook only are jewel cases. The SACD versions have been OOP for a while though.
