JoelSim:What's your view on the Audio Analogue amps?
excellent...the pre is supurb, very good m/m m/c phono section, two pre outs for bi amping. build quality is like a brick out house.
the power amp, dual mono, twin transformers, two sets of speaker outs, easy for bi wiring.
2 x 60 rms into 8 ohms, 2 x 160 into 2 ohms it has grunt.
very laid back, some say the closest you will get to a valve amp, but s/s.
considering there 10 years old aprox i have no desire to change, suit my dalis down to the ground.
prices for second hand are silly, a bellini pre just went for under £200 on flea bay, the power goes for aprox £200/£250.
at todays prices you would need to put down well over a grand to replace with the same quality.
highly recommended.
