rotel ra-10 vs ra-05se
germe
8
Hi Guys,
i have to choice beetwen these two rotels.
ra10 320 eur vs ra05se 400 eur
which one is better in term o quality sound, bass extention and power?
i currently have indiana line arbour 4.06 speakers but i will probably upgrade with new speakers during next months
i mainly listen electronic music, jazz and experimental pop
thanks a lot in advance
germe
8
last up... i really need opinions for these 2 amps.
i'm gonna to buy one of them tomorrow.
thanks
thanks
No idea about the RA-10. Have heard the 05 (original) connected to B&W 685 at a dealers. Sounded okay but had nothing to compare it with. Best advice is to get down to your nearest dealers and listen to the RA-10 and compare it with another current make.
Dave2860
32
I have a Ra-10, I love it. I think its a really good amp and would reccommend, Its very balanced and sounds just like it should. If you know what i mean?
germe
8
thank you guys,
as i understood rotel ra-10 is more balanced with a better sound mix but ra-05 is more poweful
Cypher
156
Rotel RA-10 / no remote, 40 watts/8 ohm
Rotel RA-05SE / has a remote, 40 watts/8 ohm
Hope this helps.
germe
8
Hope this helps.
yup, thanks.
these are the specs...but what about the real sound stage? :)
germe
8
plastic penguin said:
Why are you limiting yourself to one amp?
what do you mean?
other brands?
all suggestion you want are welcome :)
my budget is 400 eur max
Dave2860
32
Just go buy a ra-10, its loud enough for any form of listening, Not house party loud.
Just take the plunge and if you dont like it send it back?
Dave2860
32
It's loud but it does get warm and can't handle full volume with bass on full for anything longer than a hour, it gets too hot, the Cambridge sr10 is rated at 85w and there's not much volume in it.... If you buy the ra-10 you won't be disappointed.
KidKomet
18
This is almost painful to read and I would advise against it heavily. If you really feel like you require that much more bass, either add a subwoofer to the mix or better yet, upgrade the speakers. Please don't stress your amplifier in this way, especially as you like the sound it produces so much.
danrv
14
That does sound like stressing the amp out. I prefer the sound with tone defeat engaged.
+1 for the Rotel RA-05se. I had the RA-01, same watts per channel but no remote. Neutral sound with good bass. Just avoid partnering with forward sounding speakers. Go for it! Not much wrong with Rotels.
germe
8
as i understand they are pretty the same amps.
i think i will go for rotel ra-10. 320 eur against 400 eur and i dont need the remote.
thanks guys for your help
Dave2860
32
You must remember I am 18. I have house parties :) I used my rotel as it was already set up and my speakers can take it at full load and it was cutting out/overheating.... My old amp (cambridge sr10) now makes an appearance when Im having a party.
I usualy listen around 1/2 volume with all control set to the middle. :)
Dave2860
32
You wont be disapointed :)
