Rotel & PMC system matching
Helix
23
Hello,
Would a Rotel RA-1520 amp be good enough to drive a pair of PMC DB1i's?
And would they be a good system match?
I'd appreciate any comment or opinion.
The Rotel has 2x60W and would be driving 8ohm nominal impedance at a sensitivity of 87 dB 1w 1m. Personally I think that will be absolutely fine. They're an average sensitivity in general, fairly good for a small monitor. With the Rotel you should get a surprising amount of bass punch and rhythm too. The amount of absolute volume you get won't be concert levels but I imagine they're going to be in a small room anyway. The room size and distance you sit from them will be key in determining the ultimate volume capability available from the matching.
Aha I thought you sold the RS6's and replaced them with the PMC's PP.
