Ripping in itunes
shooter
210
I've ripped a few cds to itunes and some of them separate. Is there any way of putting the cd's 'back together' One particular cd that has 13 songs is totally seperate. With windows media player you can drag and drop but not with itunes on a mac. Any ideas!
John Duncan
This usually happens when you have different artists on one disc. If this is the case, select all the tracks, right click and 'Get Info', go to Options, then mark as 'Part of a compilation' - that should sort it.
harveymt
182
Highlight all the songs belonging to the album. Right Click and select Get Info. Select the Info tab. Change Part Of A Complilation to Yes. This will group all the songs into one. I think it happens if things are different in the information. I usually got it when ripping compliations with different artists or if an album had say Artist for some songs then Artist Featuring Other Artist on others.
