RHA MA450i Or SoundMAGIC E10S
camcroft
938
575
19,770
Hi. I own the above RHA earphones of which one side has just for no apparent reason stopped playing. I like the sound of thr RHA earphones but they do seem to suffer from build quality issues of which I have read about on various forums. I dont really know what to do. I also own the Soundmagic E 10 earphones but have read many good reviews on the newer E10S model could someone please guide me as to which model I should choose I can get another set of the RHA ones at a reasonable price but worry that they might fail or do I go for the Soundmagics. Thanks in advance for any suggestions.
rich51080
183
Spend a little bit more and go for either the Fidue A73 (best earphones under £150) or RHA MA600i which have better buld quality with aluminium housings.
If you do have to stick to budget under £50 then I would go Fidue A65 for £50. http://www.hifiheadphones.co.uk/reviews/fidue-a65-in-ear-headphone-review-a-load-of-fun-for-half-a-ton/
If it were me I would save a little more money and go A73's - they are OUTSTANDING earphones. They to my ears take on earphones costing 2 maybe 300 pounds.
