replace QA 2020s with 2050s (2000 cinema pack)
chiglee
10
should i replace my Q Acoustics 2020 fronts with 2050s
& if so could/should i Bi Wire the 2050s
any thoughts or comments on what the result will be???
onkyo TX-NR609, Q Acoustics 2000 cinema pack,
What would you like to achieve? I have the 2010i (back) and 2020i (front) and realy like the setup.
:bounce:
pioneer7
184
Hi chiglee
Upgrading to the 2050s would be a great upgrade, i have heard and seen these speakers and can say they a fantastic speaker for the money they are hard to beat, there is a review in this months edition of what hifi mag out now, they gave 5stars
they look really nice as well especailly in the gloss finish, but as always try to audition them your self take along a CD Blu-ray DVD and see for your self if you think it is worth the upgrade.
Hope this helps
pioneer7
184
Sorry as for bi-wiring if you can audition the speakers ask the dealer if they can use bi-wire cable as well, most good dealers would have this available, if your taste is music over films this should give some benefit, as for films i am not sure if this would be worth the extra out lay, but as i said check it out for your self.
