reliable android tablet to be used as remote control for hi-fi?
harry_t
32
Hi all!
can you suggest any reliable but not very expensive tablet (samsung galaxy or ipad are off budget) to be used as remote controller to stream music from a nas in a hi-fi system? I'm seeking any reliable device less than 200 euros (170 pounds). I know that there are available wi-fi tablets that cost something like 99 euros but i am very sceptical about buying these devices (even if their primary task will be as remote controllers) Thank you in advance.
Regards,
Harry
hi bigboss and thanks for your prompt reply!
i will be using as music streamer the pro-ject stream box ds net and as NAS the western digital my book live 2tb
Check out the shopping channels on tv,
QVC does the prestigio & other brands,
Ideal world does the joytab, gotab & other brands,
Argos tv does the CnM & other brands.
You best option is this app:
http://www.imediashare.tv/
Via this tablet:
https://play.google.com/store/devices/details?id=nexus_7_16gb&feature=microsite&hl=en
pro-ject has its own application for apple & android the box control, i just need a decent tablet to stream my music from NAS and feed my amplifier. Nexus7 16gb (8gb not available) in Greece is quite expensive 290euros. If i choose this price level i prefer samsung or ipad mini
I use a Creative Ziio7" tablet as a Squeezebox touch controller and uPnP controller. It's only £60 but is limited to Android 2.2 and has a resistive touch screen.
