Recommend me a cable...
Hi
Looking for a decent cable to connect a DVD/Blu Ray player to my stereo amp. Will need to be 3-5m long.
Don't want to spend a fortune...
Any recommendations?
d4v3pum4
40
I use a couple of these in my bedroom setup inc. DVD player to stereo am. They're well made, cheap and well shielded so if I ever get round to fitting my new kit in my car, they will also be used there.
www.audiovisualonline.co.uk/dynamic/eshop_products.set/ref/1606/ixos-xha215-phono-cable-/display.html
Profigold also worth a shout if you're on a budget. I can also vouch for markgrants cables, slightly more expensive but top notch components used, hand built and tested.
http://markgrantcables.co.uk/shop/index.php?main_page=product_info&cPath=43_1&products_id=1
Hi
I went for a Qed Qunex 1 which I got for £20 for 5m - seems like it will do the job.
I would recommend starting at the low cost end.
Buy on the internet so you can return if not happy.
If you keep it and upgrade later you also have a standby / spare if needed.
Look here for about £6 - send it back if its rubbish.
http://www.amazon.co.uk/Metre-Quality-Plated-Phono-Cable/dp/B0015EWQPC/ref=sr_1_1?ie=UTF8&s=electronics&qid=1231676522&sr=1-1
d4v3pum4
40
I have one (older purple version IIRC) in my system connecting my SB3 to my amp. It's no better than the cheap ixos one I linked to but £20 for 5.0m is a bargain. I would say, keep the length to a minimum though which should keep things tidier.
