Q
QuestForThe13thNote
It does impact the sound I think. I’m sure someone on here will tell me the distortion is inaudible for some technical reason.
Obviously we don’t tell them apart by measurements but by our ears as you say, but I always found it interesting messing around with old arcam and cyrus amps versus the av amps, like onkyo and Sony, when you can use these 2 channel amps in ‘home cinema bypass mode’ (the 2 channel amp powers the front speakers in home cinema mode but can still operate as a 2 channel amp when home cinema system off) and without exception the 2 channel amps always sound better than using the av amps, disconnecting bypass etc, and using the av amps as 2channel amps. if you spend more on av amps less of an issue, but this Sony was £500 In the early noughties, and that would get you a good cheap audiophile amp made around that time of the Sony that is better than the Sony. A no brainier really.
