Is this for headphones or speakers? In other words do you need a head amp included with the DAC? And more importantly what is your budget?
I just dug this list out (thanks to ccfoodog of head-fi - ori post here (http://www.head-fi.org/t/507559/list-of-dacs-that-work-with-ipad). I will paste the main list below.
There's more info on the above link about power. I'm sure I heard somewhere that the Audinst HUD-MX1 works, which is not on the list. I have that one but I don't have an iPad so I can't test it.
[ Last update 11/28/2010 ][/b]
Confirmed works
- Nuforce uDAC [Skylab, Headphoneaddict, uofmtiger, torcik; BryanP reports too much power error]
- DacMagic [uofmtiger]
- Xitel Pro Hifi-Link [deadie]
- Predator [jc9394, HeadphoneAddict] (have to put the volume to 100%)
- iBasso D4 [Headphoneaddict (see post #59)]
- iBasso D1 [trickywombat]
- iBasso D3 [hypoicon]
- iBasso D10 [qusp - doesn't work; HeadphoneAddict (see post #59), rhw - works (charging off)]
- iBasso D12 [dsissitka]
- Pico DAC [Headphoneaddict, warp08]
- Micro II usb/digital [kredmore]
- Headroom Total BitHead [qin]
- Headroom Desktop Portable amp w/DAC [muski]
- TTVJ Portable w/DAC [grawk]
- TTVJ Slim DAC/Amp [gopack87]
- Fiio E7 [Jack-Micca, feiao]
- C&C F1U USB DAC/Amp [phytonix]
- Meier Corda Symphony DAC/Amp [Noumenon]
- Little Dot Dac1 [uofmtiger]
- devilsound v2.1 dac [decur]
- Music Hall DAC 25.2 [Skylab]
- Vivid Technologies V1 USB DAC HD AMP [ccklone]
	- Valab NOS USB DAC [ccklone]
	- Aune USB DAC/AMP [ccklone]
- Sigtone h1 - without any trouble [rhw]
- USB monica NOS DAC - no problems [rhw]
- DACport (works after flash update, needs external power plugged in) [HeadphoneAddict, shigzeo]
- HA Info
NG Coax USB to SPDIF Converter [rhw]
- maverick audio D1 [Mavwong]
- Keces DA-151 USB DAC [maogua]
- Hot Audio DAC Extasy (plug USB cable into DAC and Camera Kit First, then into iPad) [grokit]
- HA NG98 [roymor]
- Firestone Libby (headphone amp) and DAC [shigzeo]
- Firestone Rubby (power amp) and DAC [shigzeo]
- Musical Fildelity V-DAC [Dwaalspoor98]
- Buffalo32S [erd]
- Headroom Desktop Amp [Durandal]
- PS Audio DAC Link III [DjAmTraX]
- Little Dot DAC mk II [alysony]
- 3MOVE [HeadphoneAddict - see post 59 for instructions]
- XM5 [HeadphoneAddict - see post 59 for instructions]
- Vivid Audio Tech V1 [HeadphoneAddict]
- nuForce Icon Mobile [yukster doesn't work; HeadphoneAddict - works, see post #59 for instructions]
- Beresford 7520 [Bazzman]
- Project USB Box [Bazzman]
Issues(?):
- Headphonia DAC cable [qc98, shigzeo - works; utdeep - works but seems "lifeless"]
- PopPulse PCM 1796 DAC [rhw - first an error message, but after reconnection works fine]
Doesn't work
- MobilePre (legacy) [porieux]
- iQube V2 portable [Skylab]
- Yulong D100 home DAC [Skylab]
- PWD [jc9394]
- uDAC-2 [headphoneaddict]
- Hot Audio DAC-Extacy USB DAC [ccklone - dialog box;too much power]
- M2 Hiface USB stick [ccklone -
not really a DAC, but didn't work feeding a "known good" DAC]
- Superpro 707 USB [jankovic]
- Soundprime de-jitter box/DAC (24/96) [shigzeo; WORKS with iOS 4.2! - shigzeo]
POWER WORKAROUND:  A number of people have noted that a simple workaround to DACs that draw too much power is to plug into a powered USB hub.
