Receivers + active speakers + sub...
AlmaataKZ
295
I am considering a new receiver (e.g. yamaha rxv3900 or rxv1065) and I plan to use it with active speakers (front R and L will be active). There will also be a sub that will be connected NOT to the sub pre out but will have to take signal from F and L speaker signals (because I have to connect the sub this way to also use it in stereo when playing music without the receiver).
The question is - will there be a way of telling the reciever not to filter out the low frequencies, not to send it to the sub out but send it to fron L and R (i.e. having the sub 'off')? And, if yes, is there a way to still use the automatic speaker setup on the receiver?
I do not find this in the manuals...
http://yamaha.ca/av/PDFs/Receivers/2008_Models/RXV3900_Manual.pdf
http://www.yamaha.ca/av/PDFs/RXV1065_Manual.pdf
Hi Dennis,
You should be OK with the Yamaha.
Normally on the LFE set up you can send the LFE frequencies to main, main + sub or sub only, so setting the receiver to output the LFE to the mains should achieve what you want.
Thanks, David (we just spoke on the phone btw re various outgoing yamahas
What is "pre-amp mode"? Is it any different from just using the pre-outs?
EDIT: i have checked the pre mode in the manual now - it basically switches all the power amps off. Not really useful for me as I only plan to use R and L fronts as active so still need teh other power amps on. What woudl be nice is a processor like av8003 + 3 mono power amps, triggered on only when required.
chudleighpaul:
Hi Dennis,
Thanks a lot!
