manix said:
				SeriouslyCinema said:
				manix said:
			It is quite discrete but I think the TV position is all wrong - basically too high with regard to the seating postion and distance to tv
My other question would be in reality the speakers would be a comprise over traditional boxes in sound quality. At what point does atmos out benefit shear sound quality of a say a 5.1 system? It there a point at which this happens? I suppose it really depends what you are listening to.
TV isn't too high and you can only work with the space you have.
In wall speaker are not a compromise over in room speakers. The opposite actually.
This system will not only outperform many high end 2 channel systems but delivers stunning movie performance too.
I'm not sure you can say for a second the tv isn't too high if it's above the top of your head. The only way to view is by angling your head back.
With your head at the back wall and no speakers behind you I'm really not sure how it is possible to get a proper dimension to the sound that is intended to be behind you?
You say in 2 channel mode this system will out perform many high end two channel systems. That I cannot confirm as I have not heard your system side by side. Some words of wisdom though do think or do you know? But there is something I definatelty do know you are miles off the listening axis for the front the front LR speakers due to your head being so low compared to their postion so even if they were the best speakers in the world due to your seating postion you will never here how good they are properly.
I am sure you are an expert in all things audio,  but we do this for a living, installing systems up to  £300K for the audio alone.
Dimemsion of sound behind?  Surround back speakers are not employed in this system as it's 5.2.4.
There are no issues with off axis response either as the tweeters are slightly above seated head height. No discomfort in the neck whilst viewing as the sofa supports the back and neck.
This is not a dedicated room but a sitting room where some compromises will exist. Compromises or not, the system sounds and looks stunning with all types of media.
