Quick Question re: Blu-Ray Players
Hi guys,
I have a Sony Blu-Ray player (BD-PS360) and I was wondering if it can play DVD's from any region (i.e. region 1, 2, 3 and 4)?
Thanks.
hello
It depends where you purchased it from as some shops sell multi-region versions,otherwise the only other way is to use a one for all remote or harmony remote to hack the settings.worth a quick check on google to confirm this.
If it's not multi region then no, search your model number with remote hacks that should work!!
