qed silver annivesary
carter
211
what would be an upgrade to this cable that would match my kit (in bio)and could i upgrade the fronts and leave the rears with the silver anniversary
i could aford to put a good quality cable on the fronts but not really the rears .(i no this is a hi fi/av question but i no most you guys visit all fourums)thanx
Get some Chord Odyssey 2 or the slightly thinner and cheaper Rumor. Both very good cables and, in cable terms, well worth the upgrade. I went from Chord Carnival Bi-wire to Odyssey 2 and in particular found improvement in the bass and treble.
carter
211
hi iggle, so is that a warm or bright cable and would it matter if i leave the rears with qed oh and should i do the center my main aim is to get really good stereo sound but i dont want it to ruin the intergration of the rears/center
I went with Chord Odyssey 2 upgrade form silver anniversary...the difference is night and day...far superior cables, well worth the money.
nodnarb4444:
Hmmm, well, a question that I can't answer from any experience. Personally I would aim to upgrade all cables to the same level; yes, blue sky thinking, I know. A guess would be to do all the fronts at least so that the primary 'noise makers' for movies sound the same.
Are Odyssey 2 and Rumor bright cables? Well, no, but it depends on your kit as to the outcome you get. Given that you're coming from QED cables I'd like to think the Chord cables will be far more neutral and definitely not brighter. Some find that silver coated copper cables are bright but I would put that down to their system and room.
For me, Odyssey or Rumor would be a risk worth taking and I don't think you'll be disappointed.
carter
211
thanx iggle
the fronts and center are defanatly gonna get done.
i guss it will be a bit of a lottery with the rears just cant really streach to another 50meters for the rears hopfully it will sound ok in av as thay are just surround speakers and are only small and dont have much bottem end.
do seven oaks stock it as im shaw rs dont i also have an audio t near me.
carter
211
thanx also scott its always good to hear more than one vote for upgrade iwill upgrade in the next week or so and post my findings
oh did you find it improved over time
Dave_
1,211
614
20,070
I wouldn't worry too much about not upgrading the rear cable's they're just FX speakers,after all,it's the front three that will being doing most of the work.I use Chord Odyssey for my front's/centre and am using Chord Leyline for the rears with no detriment to SQ etc.
nodnarb4444:
Definately. As always you must give the cables time to "break-in", like a fine wine, they will mature as time passes. I particularly noticed this in the bass department and the upper mids. When I first bought them I was blown away by the differemce in quality. After 2 weeks of music listening, the bass was very pragmatic.
Also worth a note, I have never heard so much detail in the upper mids as I have with the Odyssey, definately not a bright cable. The Chord is less bright than the QED, with far superior control throughout the bandwidth...defo worth the money...one of my best investments.
Pleased the opinions have influenced you
pete321
145
I just upgraded my QED SA because it was too bright/harsh on the top end. I went for 2 runs of QED Revelation to bi-amp my fronts and it was a major difference. I found they gave improved bass and much more depth to the midrange, plus they tamed the harsh top end, pretty much did what the WHF review said.
vinod_david
154
38
18,620
Hi:
I would like to upgrade speaker cables for better bass, am coming from SA XT. So, will Chord Odyssey 2 go with my setup and improve the overall sound. thanx all.
Upgraded my front and centre speakers from Silver Anniversary to Chord Odyssey 4 a few months ago. Much more detailed and balanced sound.
