Qed profile hdmi
Tristy
23
Does the latest qed profile support Ethernet and audio return channel?
It only says v1.4, but that means nothing as I've learnt!
professorhat
992
22
18,895
It won't necessarily support Ethernet I don't think - as you say, 1.4 shouldn't be used to describe a cable - it should say High Speed with Ethernet if it does support it. However, a quick check on the QED website (link) shows the QED Profile cable has the High Speed with Ethernet badge next to it, so this shows it does.
Whoever is advertising it as a "1.4 cable" should be contacted and told to stop (assuming it's a company) as this is misleading.
Tristy
23
Thanks guys. All very confusing with this version badging.
You are right it does say Ethernet high speed on the qed site.
Does a cable with Ethernet and high speed automatically have the audio return channel?
professorhat
992
22
18,895
Yes, audio return channel (or ARC) is part of the High Speed spec, as is the ability to pass 1080p and 3D signals.
